It is currently Thu Apr 16, 2026 10:15 am
Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3  Next
 Longtail...home made
Post Re: Longtail...home made
Sun Jan 26, 2014 11:24 pm
Making a parenthesis, but knowing us better, I want to show you, what I've built ... inspired me from the web, but also with the help of people in Italy.
I was hard, but I've worked with passion, and I have led the project up to the end of work. I hope .... with your help, this time, to go and this project up to the end of work.
On that site, I wrote under the name of user 'ginghis'
http://www.gommoniemotori.com/forum/vie ... 35&t=14512
And this is a clip with final product !
http://www.youtube.com/watch?v=YmgjU_O8Ol8
It is true that here, in Romania, the rate of use of these type of engines(mud-motor) is 0. I'd like to think that I am first of such engines....may be. :mrgreen:
I typically use an engine Honda BF, 15 hp, 4t, but I have had situations, where in the Danube Delta, we couldn't pass over some obstacles with my engine. For this reason, seeing how many advantages provides this type of engine, I decided to start construction of such a motor.
Mon Jan 27, 2014 12:09 am
Today we've worked least mud ...
For handling motor left-right, I'd have two options:
-metal-to-metal, with a fin to lubricate parts in contact.
-or else, with a thrust bearing.
I haven't decided yet, but I feel inclined to bearing. :?
Thu Feb 06, 2014 11:15 am
You shouldn't need a bearing. Metal to metal would be fine. If you want it to be really smooth add an oilite bushing. (Like this )
Here is a pic of a homebuilt mounting bracket for reference.
Thu Feb 06, 2014 11:41 am
Thu Feb 06, 2014 11:58 am
that is a very small amount of adjustment in that picture. I doubt it would make much difference.
Thu Feb 06, 2014 12:02 pm
I don't know the role of this blockage ! If someone can tell me!
Thank you!
Thu Feb 06, 2014 11:21 pm
It locks the mount straight when the motor is rotated 180 degrees into the boat while pulling the boat on the trailer.
Every day I'm paddlin'
Thu Feb 06, 2014 11:49 pm
OK ! I understand !
Thank you, sir!
Fri Feb 07, 2014 10:26 am
Good evening ! After I've documented, from the first support I gave up, and I decided to make another. The support, momentat is painted with a primer auto, but I don't want at the end of the project, to dye camouflage .
Wed Feb 12, 2014 11:28 am
In the meantime, I also bought a universal coupler !
Wed Feb 12, 2014 11:31 am
Your transom mount looks great!
Will you weld a piece of flat plate across the top for the engine to mount to?
Wed Feb 12, 2014 12:13 pm
Thank you!
I don't think so, v-sheep do that after, I finished queue engine, otherwise I don't think that it can balance .
Wed Feb 12, 2014 12:21 pm
Thu Feb 13, 2014 10:39 am
Looking good!
Also your new universal joint should work much better than the first one you showed us.
Thu Feb 13, 2014 11:52 am
Today we've worked something ... and bearing boxes are working on turner .
Tue Feb 18, 2014 11:06 am
Looking good buddy, where are you from?
35 GTR chasin a BBC 1848
Thu Feb 20, 2014 7:36 pm
Thu Feb 20, 2014 7:42 pm
Thu Feb 20, 2014 7:50 pm
Thu Feb 20, 2014 10:36 pm
Today, arrived parts ! :D
Fri Feb 21, 2014 11:40 am
Where did you order the bearing assembly from?
Fri Feb 21, 2014 11:56 am
I've ordered from a friend... works at a factory ...
Fri Feb 21, 2014 12:06 pm
It looks like it will work great.
Fri Feb 21, 2014 12:27 pm
I hope ! :mrgreen:
Thank's !
Fri Feb 21, 2014 12:42 pm
Thats a good looking bearing set up
Quote:
Fri Feb 21, 2014 9:32 pm
Fri Feb 28, 2014 10:23 am
I think heavy for the bearing assembly is good. If it fits the shaft, it will work well. As long as it doesn't weigh 40kg :D
Fri Feb 28, 2014 11:25 am
Fri Feb 28, 2014 1:38 pm
Sat Mar 01, 2014 7:10 am
Sat Mar 01, 2014 2:34 pm
Sat Mar 01, 2014 9:24 pm
Hows the boat your putting it on going to like that weight on the transom?
Sat Mar 01, 2014 11:22 pm
For moment, I don't know...but I like put on a "jon-boat" !
I hope, building a "jon-boat"...and I think is the best for my long-tail.
Sun Mar 02, 2014 6:03 am
Sun Mar 02, 2014 6:49 am
Sun Mar 02, 2014 9:23 am
Recently, I bought a inductive tachometer ... I wrapped 4 turns on the spark plug, and we filmed a few values of engine speed.
Mon Mar 03, 2014 1:00 pm
Tue Mar 04, 2014 5:17 am
To get the max RPM's. The more RPM's the faster it will turn the prop.(Go faster)
Tue Mar 04, 2014 6:53 am
I understand ! ... but this will not affect engine ?
Tue Mar 04, 2014 10:24 am
