It is currently Sun Apr 12, 2026 7:20 pm
Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3
 Longtail...home made
Post Re: Longtail...home made
Should be alright as long as your prop size is correct. You just have to be careful revving the engine without the prop in the water to avoid high rpms without the governor in service
1436 Lowe
Tue Mar 04, 2014 1:38 pm
Depending on the conditions you are running in I would advise against removing the governor. It's easy to hit something under the surface and have the prop jump out of the water. I would assume this will put your motor at risk w/o a governor.
Tue Mar 04, 2014 4:52 pm
I would run with out one for sure you will get valve float which will limit the rpms before you pop the motor on a small honda or clone. The valve springs are only good to around 4100 in most clones/Hondas and if you happened to get larger springs that motor still will not spin over 4500 stock and shouldn't hurt a thing even if held wide open out of the water for a couple of minutes.
Tue Mar 04, 2014 8:25 pm
I've just bypassed the governor the way the throttle is hooked up, I have made the tiny tach hit 5600 :shock: before letting off... You will have no issues running without the governor, just dont let it spin those high rpms for an extended amount of time and you'll be alright, the prop in the water is enough of a load to keep the rpms in a safe range without the governor.
1436 Lowe
Wed Mar 05, 2014 12:03 am
Noticing that opinions are divided. However, shall take into account all your advice, and study them carefully. But for the moment , I let the engine so ... with guvernor. Maybe I can try and without . Thank you all for answers! ;)
Wed Mar 05, 2014 6:57 am
It takes time, but its looking good.
Wed Mar 05, 2014 8:57 am
I have received one more piece.
I appeal to this trick, because I didn't find a universal coupler to match the motor shaft.
Thu Mar 06, 2014 12:37 pm
The only this I'll say is it better be perfectly straight and true or it will vibrate itself to pieces. I can show you some photos i my first attempts down this path. Other wise http://www.driveshaftparts.com/componen ... okes/1000/ have what you after too.
Quote:
Thu Mar 06, 2014 11:17 pm
Unfortunately, as I have written, in our country, the rate of use of these types of engines (mudmotor), it is 0. That's why it's hard for me to get necessary components. Universal coupler which I put it in pictures, is used when, ATV's, and I hope to be quite strong. Anyway, in part built, I used quotas very tight, without a tolerance.
What you showed me you have, it is not very expensive, but I'll see what I can buy it.
Thank's !
Fri Mar 07, 2014 1:10 am
Fri Mar 07, 2014 1:36 am
Actually what is a Romanian dollar worth? Whats a 2 litre of milk and a loaf of bread worth?
Fri Mar 07, 2014 1:44 am
Fri Mar 07, 2014 3:27 am
I work something ...
Mon Mar 10, 2014 12:18 pm
More..
Tue Mar 11, 2014 11:25 am
I like that idea better.
What kind of fish you catching on the delta?
Tue Mar 11, 2014 11:38 am
As a matter of fact, for me, fishing is only motivation for walking in wild places. But catches a few varieties of fish : Caras, carp, catfish, rosioara, Ray's bream, etc. The most common, is carasul and carp.
Tue Mar 11, 2014 12:00 pm
I have a question ! Normally, in what length is yes thread the shaft?
Thank you!
PS : Picture, I found on net .
Wed Mar 12, 2014 11:28 am
If you have your prop measure it plus 2 nuts and a little bit more for extra. Put one nut on then the prop then another nut.
Sent from my beeper
Thu Mar 13, 2014 3:52 pm
Hello ! I'd like to know, that I have not given up on the project, and that's why I'd like you to accept my apologies for that I haven't posted. In the meantime I purchased two propellers (aluminum). You are currently working on a boat of glass fiber (for my) and this was pretty much the reason I've been working on mud engine
Tue Jul 01, 2014 4:38 am
Looking good! Be sure to look into getting a stainless steel prop... Those aluminum ones wont last...
http://www.backwaterinc.com/props.html
1436 Lowe
Tue Jul 01, 2014 6:53 am
If everything will be OK, I think I'll buy and a stainless steel prop.
Thu Jul 03, 2014 3:19 am
