It is currently Wed Jul 02, 2025 10:39 pm
Reply to topic  [ 135 posts ]  Go to page Previous  1, 2, 3, 4  Next
 GTR 35 arrived today!
Post Re: GTR 35 arrived today!
[color=#80BF00][b]Excel 1860 swv4f4 with GTR35L with stage 1, cam, exhaust, heads
Thu May 22, 2014 7:44 am
It's always good policy to carry a spare prop! Never know what will happen
Samsung S5
Thu May 22, 2014 8:10 am
Thu May 22, 2014 9:59 am
Be sure to get some pics up -
Thu May 22, 2014 10:23 am
Thu May 22, 2014 10:24 am
Only pic I have at the moment.
Thu May 22, 2014 10:28 am
very nice - did you order black?
Thu May 22, 2014 10:32 am
Thu May 22, 2014 10:39 am
They just sprayed part of your 550$ stainless exhaust. awesome. :lol:
It burnt off while it was warming up. Lol mostly overspray.
Thu May 22, 2014 10:40 am
Thu May 22, 2014 10:42 am
Thu May 22, 2014 10:46 am
True, but Pete 14 why not get one of each. Considering most have said the 3 blade has some flaws in certain areas, ie lilies, veg. You have a prop for every situation. Me I carry a bb for speed when light, a hammer for heavy load, and mud
Samsung S5
Thu May 22, 2014 10:51 am
Thu May 22, 2014 10:56 am
Thu May 22, 2014 11:12 am
Moving the pin up did not make a difference. Still maxed out on my up trim.
Thu May 22, 2014 1:48 pm
Move to top pin .. That's where my boat runs best even though it's a 25 ... And I still have upward trim available
1744 WC Custom
25 GTR
Thu May 22, 2014 1:55 pm
17x54 Extreme W/ GTR-35L Stage 1
Thu May 22, 2014 1:59 pm
Thu May 22, 2014 2:21 pm
Thu May 22, 2014 2:24 pm
Thu May 22, 2014 2:27 pm
MMT Moderator
Post GTR 35 arrived today!
First off congrats on the new motor.
As others have said move the pin up a hole on your transom bracket. This will cause engine to ride higher. Run it & check trim / prop position. Ideally you want be on plane and lose speed trimming up as prop rises out of water as your full speed ahead. When you trim slightly back down you'll regain speed and that's where you'll want to run it 75% of time. When in soft mud / shallow water trim down to maintain steering and control of your rig. If hard bottom hammer down and pray you don't get thrown forward :)
GTB 1860 w/ 2019 GTR40XD-HO
Thu May 22, 2014 2:31 pm
Thu May 22, 2014 2:42 pm
My boat was a 15 degree transom, and when there were 3 holes on the GTRs I ran it in the middle hole with plenty of up & down trim.
Pete just for shits and giggles, make sure you can hit 4700 rpms in neutral. Slowly rev the motor up.
Thu May 22, 2014 2:46 pm
Thu May 22, 2014 4:42 pm
Pete you should be set to hit 4700 in neutral.
Thu May 22, 2014 5:13 pm
Check your linkage and throttle cable and make sure your carb is able to open to 100% travel.
Thu May 22, 2014 5:15 pm
If your not sure what you are looking at and messing with, you can always remove the air filter box fairly quick and verify that you are getting wide open throttle via the butterfly on the carb
Thu May 22, 2014 5:17 pm
That was my next step. Haven't had time to check,it but I will tomorrow. Do I just loosen the screw holding the cable down and make sure it is traveling all the way open?
Thu May 22, 2014 5:25 pm
mine only gets 4400-4500 WOT stock motor should I be hitting 4700 also, if so I will be doing the same as you pete
Thu May 22, 2014 6:21 pm
Hard to tell but from the pic it looks like you have slack in your throttle so like OD said maybe your not getting full travel on your carb
1754GT 35GTR
Thu May 22, 2014 6:47 pm
The throttle lever has about an inch of play before it revs. You can zoom in on the picture I posted and see what I'm talking about.
To fix this if it is a problem, do I just loosen the throttle screw that holds the cable in place and pull the cable and then 're tighten? New to the stock carb stuff so any help is greatly appreciated.
Thu May 22, 2014 8:10 pm
Yea loosen up the screw that holds the cable and adjust the position. You want to get it to where you reach full travel on the carb before the lever comes in contact with the handle.
Thu May 22, 2014 8:32 pm
Thu May 22, 2014 8:41 pm
Thu May 22, 2014 8:50 pm
Thu May 22, 2014 8:54 pm
Thu May 22, 2014 9:01 pm
Thu May 22, 2014 9:02 pm
Don't they run those things before they ship them out?
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Thu May 22, 2014 9:05 pm
Thu May 22, 2014 9:08 pm
Users browsing this forum: Google [Bot] and 148 guests
