It is currently Fri Jun 27, 2025 12:35 am
Reply to topic  [ 27 posts ]
 CRACKED BRIGGS BLOCKS!!
Post CRACKED BRIGGS BLOCKS!!
I want to know who out there in the mudmotor world has cracked a Briggs 32/35 block? I have seen 3 in the last month!! 2 on ProDrives and 1 on a Go-Devil!!! All of them cracked in the valley between the cylinder heads and just to the right of the fuel pump. If i took all 3 of the engines i have seen and stripped them down to just the block they are dam near identical where they have cracked!! :evil:
Mon Jan 04, 2010 11:00 am
Post Re: CRACKED BRIGGS BLOCKS!!
+1
looking from the front of the engine cracked down the left side of the fuel pump along the curves of the valley....
Are you finding this in stock engines also... mine was modded so i thought that had a lot to do with it.
Mon Jan 04, 2010 11:08 am
looking at the fuel pump it would be the lower right side area. near the lower right bolt that holds the pump down.
Mon Jan 04, 2010 11:13 am
wish I had pictures... but didn't take any before i shipped it back to get fixed... are you seeing this on stock motors? I have heard that the 08/09 motors are cracking blocks... the 07 models and earlier are doing fine even if they are modded
Mon Jan 04, 2010 12:26 pm
Mon Jan 04, 2010 1:13 pm
got one if you are collecting them....... :mrgreen:
this is with a stage 2.....why is this the first time i have heard about peoples stock motors cracking???
dont have any good pics but this is a view from the inside.
Mon Jan 04, 2010 2:54 pm
Mine cracked on the bottom next to the sump. Up in the recessed area between the oil drain and the pto shaft. And I know there have been others that cracked in that same spot.
18x48 Charles Leonard / 36PD
Mon Jan 04, 2010 4:18 pm
Mine decided to split this weekend from the oil filter top port all the way to the top of the crankshaft hole.
There is no replacement for displacement!!!!
Mon Jan 04, 2010 4:35 pm
How many of these are stock motors... how many are modded... mine is on the way back from EVT all fixed up and ready to try it again.
Mon Jan 04, 2010 4:50 pm
Mine was stock.
Mon Jan 04, 2010 4:52 pm
What is PD saying about this?
Crisis defines character
Mon Jan 04, 2010 5:57 pm
Mine cracked in the fuel pump hole on the back right side and ran to the case edge after it sheared the heavy duty bolts EVT told me to install on the back right side of the case cover. Too much un balanced power!! It was an 06 case with a total of 50 stock hours, and 29 EVT stage 3 hrs.
Tue Jan 05, 2010 12:24 am
These Briggs blocks just are not holding up to all the rpm's............hope my 08 stock block holds up? Gonna give guys a complex...........
Tue Jan 05, 2010 2:39 am
Tue Jan 05, 2010 7:01 am
Now that it has been mentioned, all 3 of the blocks that I have seen were all 2006 model blocks!!!
Tue Jan 05, 2010 9:03 am
06 or not!!! Give them time...The blocks can not handle what people are doing to them..Too much case pressure and torque.Keep the Rpm's down and they will last.
Tue Jan 05, 2010 9:16 am
thats why I am heading down plan b
Tue Jan 05, 2010 3:00 pm
Are there any that have cracked on a belt driven unit?Maybe it is a vibration issue or hard shocks from hitting objects?Shiat,I don't know!
Tue Jan 05, 2010 3:10 pm
Tue Jan 05, 2010 4:55 pm
Tue Jan 05, 2010 5:42 pm
Got my motor back from EVT... Not the cleanest looking repair but if it works it works...
Was told they welded a reinforcement on the inside where the mechanical fuel pump sat then looks like the poured JB weld or some type of epoxy on the outside top of the motor where the fuel pump was locate... Running all electric fuel supply now... Trying a Mr. Gasket 2.5-3psi right now. If it craps out will go to the Purolator that is recommended everywhere I read.
We shall find out if i continue to get bad vibrations... If it breaks again I think my next motor is coming from Mud Buddy (BPS).
Fri Jan 08, 2010 6:47 pm
'06 & '07 seem ta be de ones dat let loose...
Fri Jan 08, 2010 7:11 pm
1754 GT EXTREME 37EFI
Fri Jan 08, 2010 7:16 pm
Mine was a brand new '09 at least I thought it was... Sent it to EVT right off the distributor's shelf. May have to check the serial on the motor when i get a chance.
Fri Jan 08, 2010 7:25 pm
Any more on this issue? Still have block issues?
Sun Mar 07, 2010 10:02 pm
Tue Mar 09, 2010 9:53 pm
Wed Mar 10, 2010 11:19 am
Users browsing this forum: Google [Bot] and 71 guests
