It is currently Fri Jun 27, 2025 12:50 am
Reply to topic  [ 5 posts ]
 tweakin the govenor
Post tweakin the govenor
how do you tweak the govenor on the 35 vanguard
Tue Jan 12, 2010 10:51 pm
Post Re: tweakin the govenor
While standing at the back of your engine, look between the muffler and air filter box. On the righ hand side you will see a phillip head screw that is threaded thru a spring. Turn this screw clockwise to raise your rpm's. I would raise them to about 4200-4250 out of water. To check them, just sqeeze your throttle wide open and see what rpm's your turning.
Wed Jan 13, 2010 7:18 am
thanks but my tiny tack quit working so idk what rpm's im runin
Wed Jan 13, 2010 9:26 am
Then get a new Tiny Tac they ar only about 30 dollars and you don't want to get your rpms two high you will Fu@K Chit up.
1652 w/ MB Mini 35
Wed Jan 13, 2010 9:41 am
ETD88 09/28/09-05/14/2010...
Wed Jan 13, 2010 9:55 am
Users browsing this forum: No registered users and 77 guests
