It is currently Sun Jun 29, 2025 3:59 pm
Reply to topic  [ 18 posts ]
 BPS throttle
Post BPS throttle
I ordered the BPS throttle leaver to put on my go devil and like a dummy i didnt measure anything to make sure it would fit. Well i went to put it on earlier and the throttle is just a tad bit to small to fit around the handle. Anyone else have this problem and how did you fix it? I came up with two options, either find a piece of pipe that the throttle will fit well over and cut it to length i need and cut the tiller shorter then weld the new smaller piece in it's place. Or i can get longer screws that will reach then tighten it up then heat the tiller pipe with a torch and tighten the screws until the metal bends or warps to fit the hole for the throttle.
Does this sound practical or a dumb idea?
Tue Sep 09, 2014 7:27 pm
Post Re: BPS throttle
Use a dremel and open it up some . That's what I did.
Tue Sep 09, 2014 7:29 pm
Tue Sep 09, 2014 7:39 pm
Yes. Just keep taking material out till it fits. Careful its thin by one of the screw holes..
Tue Sep 09, 2014 7:45 pm
I can take a picture of it Friday.
Tue Sep 09, 2014 7:46 pm
Yea use a dremel. That's what I did also.
1646 Gatortail dragging a stage 1 GTR
Tue Sep 09, 2014 7:49 pm
Aight man thanks
Tue Sep 09, 2014 7:50 pm
- Mark Twain
Tue Sep 09, 2014 7:57 pm
You can just grind it bigger.
Wed Sep 10, 2014 2:17 pm
be sure to dip coat handle - makes for great gripping surface
viewtopic.php?f=3&t=53952
Wed Sep 10, 2014 3:25 pm
Take a little off everywhere, but take the most off here. Get rid of that hump.
Those screws are cheap. Make sure to use some grease or it will gall up.
Wed Sep 10, 2014 5:24 pm
nice - actual pictures
Sun Sep 21, 2014 10:04 am
Just finished doing the same thing.
Sun Sep 21, 2014 12:15 pm
Had a machine shop take some off my handle. No modification to the throttle. $20 and was done.
Tue Sep 23, 2014 6:18 am
can you use that throttle with a stock carb ?
07 16x50 w/ 07 35 gtr
Tue Sep 23, 2014 6:28 am
They make one for stock carbs
Tue Sep 23, 2014 6:32 am
I don't see why you couldn't use with stock carb - i used stock cable with handle and PD EFI, I had to remove about 3/8" from housing on cable to get best results at the throttle body end of cable for the EFI
Tue Sep 23, 2014 6:33 am
The end was a little smaller, but I've had no problems with it coming out once I zip tied the black hosting to the motor and clamped it down with the clamp.
Tue Sep 23, 2014 9:38 am
Users browsing this forum: Majestic-12 [Bot] and 374 guests
