It is currently Mon Mar 30, 2026 11:23 am
Reply to topic  [ 14 posts ]
 time for some mods
Post time for some mods
well after two years im having some issues w my motor.
Bad timing but o well im going to let warranty fix it then have the heads decked .030 while im in there.
Engine started burning a little oil once i got the motor hot it would smoke a little when idleing. ok no big deal keep il keep oil in it and get threw teal season and take it in, well opening day i hit a tree and snaped my shaft and prop completly off! i had to be towed in. I fixed that and made a few good hunts and the smoke got a little worse, and the last hunt i could only get like 3000 rpms in the water(like 16mph), out of water it still hits rev limiter.. so i pulled the air box off and there was some blow by oil in there. i got to the house changed plugs, fuel filter, fuel, air filter, and water seperater and did a compresion check. one side had 135 and the other had 110. they both held compresion. I put it back in the water and it still smoked but i got 26 mph out of it.
I took it to a guy in crosby tx named robert. I hear he is pretty good.
Any ideas on what it could be? If im getting 26 27 mph before head work and valves being set perfectly what do you guys think i will get with head work and my problem being fixed?
2012 gd1860 w 35gdsd
Mon Sep 22, 2014 9:43 pm
Post Re: time for some mods
Tue Sep 23, 2014 3:51 am
JMO, deck more than .030". I would go about .045" - .050", that will get your compression up to about 180 - 185. Then anything you add to it will be a compliment. As far as head work, it really depends on a few factors. What other mods do you have, is your hull hooked or look like a golf ball on the bottom, Stock exhaust? But a good set of heads ported and decked is always helpful.
Tue Sep 23, 2014 4:23 am
If you are burning oil (getting oil in the cylinder) its either:
-head gasket leaking
-valve stem seals leaking
-rings leaking
Oil blowing up the crank breather tube into the carb indicates pressure in the block. Head gasket leak between head and push rod area could be one source, rings would be the other.
Tue Sep 23, 2014 4:46 am
thanks for all the replies as far as the compression goes wouldn't it leaked out while doing a compression test if it was the rings? I also talked to warren coco at go devil and he said that he thought it could be pressure frombthe gas tank not venting off. But that was before I did a compression test. Iv been thinking valves the whole time. What mods can he do to them while he is in there? Also on the heads.030 not enough? I want to do all the mods the whole works but this will prob be it threw hunting season. Biggest thing for me is carrying a load.
Tue Sep 23, 2014 5:53 am
Boats is a 1860 gdsd boat w squar chimes. Iv been thinking of just gutting my stock exhuast and on the oil its been changed twice since iv been having these issues and its up to spec
Tue Sep 23, 2014 6:00 am
ur compression gauge will hold the pressure cause it has a valve in it! and my bet is head gasket is blown!
Tue Sep 23, 2014 6:08 am
Pop the valve covers and pressurize the cylinder and stick your finger down in there and see if you can feel a leak.
Tue Sep 23, 2014 7:23 am
thats what rpberts guess was head gasket. just bad juck or what could i have done wrong? engine was all stock
Tue Sep 23, 2014 7:07 pm
I had one go out on a bone stock motor that never turned more than 4100 rpm
Tue Sep 23, 2014 7:09 pm
if i just go with the head work and gut the exhuast do yal think i will need higher rev ciols or i prob still wont hit 4350 rpms in the water?
Tue Sep 23, 2014 9:48 pm
You will probably be fine behind that 1860
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Tue Sep 23, 2014 9:58 pm
right now before this happend i was turning 4000 in the water every since team camo tuned me up on the wallisvile run a year ago.
Wed Sep 24, 2014 4:04 am
Wed Sep 24, 2014 4:06 am
