It is currently Fri Jun 27, 2025 7:23 am
Reply to topic  [ 29 posts ]
 Mikuni question
Post Mikuni question
For those of y'all that are running Mikuni's with exhaust and heads, How do y'all have them set up?
Like i said, I've got heads and exhaust and Im about to put a Mikuni on my motor.
So what main jet are yall running? What about the pilot jet? What do yall have the jet needle set at?
Tue Feb 16, 2010 6:19 pm
Post Re: Mikuni question
165 main
standard pilot
jet needle clip was set up one from middle setting
Tue Feb 16, 2010 8:39 pm
Thanks Gary.
Anyone else?
Wed Feb 17, 2010 12:18 am
Same as what Gary said. During the cold months I like to put a 30 in for the pilot.
Wed Feb 17, 2010 6:31 am
Mitschke please document and take pics of what you do. How are you adapting the Mikuni to the engine?
Wed Feb 17, 2010 8:01 am
Just to make sure that were on the same page. What size is the standard pilot?
Marcus, i gotcha covered.
Wed Feb 17, 2010 2:48 pm
25
Wed Feb 17, 2010 4:06 pm
My mods
BPS HSR 42mm Mukuni Carb kit
EVT heads decked .055
EVT HO/loud exhaust
Running
Main Jet: 162.5 ( Tried the 165 it was to rich )
Std. pilot jet (25) ( but I plan on upping it to a 27.5, motor hesitates a little after warm up)
Pilot air screw ( idle mixture) set at 2-1/4 turns
Std. needle jet (97) set 1 notch down from center.
Std. accel. pump nozzle (70)
Wed Feb 17, 2010 7:39 pm
Preston is on top of this!
Wed Feb 17, 2010 8:24 pm
Raise it back up a notch and try a 22.5 pilot. Every vert. we have done liked the 22.5 pilot. Cold weather may require a 25.
Wed Feb 17, 2010 9:23 pm
Wed Feb 17, 2010 9:32 pm
170 main
25 pilot
3rd notch down on size 97 needle
BUCK OFAMA
Wed Feb 17, 2010 9:40 pm
I'm running a 25 pilot jet at 1 1/4 turns and still running rich.
Wed Feb 17, 2010 9:56 pm
I think I see a ghost :shock:
Thu Feb 18, 2010 5:48 am
BOO !!!! :mrgreen:
Thu Feb 18, 2010 7:35 pm
.065 decked heads, evt intake, evt exhaust, Mikuni HSR 42
165 main, 22.5 pilot w/mixture screw 1.25 turns off bottom, one notch below center on standard needle... sucks a fat one coming off idle though, always has. can't just mash it & go... gotta use kind & gentle words and once you got it convinced you'll play nice it'll start to go then you can beat it up.
Fri Feb 19, 2010 10:42 am
Fri Feb 19, 2010 11:10 am
yes I have & have plans to try it out..... but can't ever find da time not to mention I'm sick of wrenchin on dis mofo.
I'll give a free sack of crawfish to whoever can fix it......
later on when they ain't payin us $125/sack no more :mrgreen:
Fri Feb 19, 2010 11:16 am
swappin da intake isnt that hard.. But I hear ya about wrenching on crap. I got a Toyota truck that needs a front end rebuild AGAIN. I dont want to do it.
Fri Feb 19, 2010 11:22 am
I know der ain't shit to it, but der also lies an uncertainty that it don't run worth shit an I have to swap it back. Still ain't a big deal, but after countless case gaskets, cracked blocks, cracked sumps, blown engines, etc.... For once this mofo is running without any real problems to speak of and it's crawfish season so I ain't touching it if I ain't got to. Just sick of wrenchin on shit, that's all.
Fri Feb 19, 2010 12:00 pm
Fri Feb 19, 2010 2:52 pm
no... tried every clip position on the needle that's in there with no improvements though
Fri Feb 19, 2010 3:05 pm
1860 Phowler Extreme W/ stage 1 36 PD
Fri Feb 19, 2010 3:49 pm
18x60 GTB
35 GTRrrrr
Sun Feb 21, 2010 9:08 am
Mon Feb 22, 2010 2:39 am
Mon Feb 22, 2010 11:24 am
Mon Feb 22, 2010 9:21 pm
Mitschke, Mukuni makes a great carb, Your going to like it myboy.
My only dislike is the cable bracket and the white nylon sheave causing cable strands to break. :evil:
Someone needs to come up with a better design and do away with all that unnecessary linkage crap and reroute it point A= cable to point B= throttle arm 1/4 sheave. hint, hint.
Mon Feb 22, 2010 9:38 pm
Someone needs to return pm's.... Hint.... Hint....
Lol
I've been trying to come up with a design I like but I really just haven't have time to make one. Just like the reverse thing.
I am not a patient as you and I don't wanna make all of that shit by hand. Then I don't wanna mess with tooling in a cnc, because I Would have to use personal stuff here at school. But, if I went home I would have full run at my neighbors shop and I wouldn't have to buy tooling.
The more you hound me, the more i wanna finish something lol
Mon Feb 22, 2010 10:55 pm
Users browsing this forum: No registered users and 120 guests
