It is currently Sun Apr 12, 2026 1:24 am
Reply to topic  [ 53 posts ]  Go to page 1, 2  Next
 GTR High Speed come apart!!
Post GTR High Speed come apart!!
So had a little mishap last week. After trying to fix a drive belt too lose and thinking a previous owner put the wrong lower pulley in I installed a 48T pulley... Well guess it was a little too tight. :roll: . So now I got to redo this thing. Has anyone ever puller the shaft out of the planetary?
Wed Jun 08, 2016 2:06 pm
Post Re: GTR High Speed come apart!!
WOW!
Good luck with that one...
Did you not have a tensioner gauge to check how tight the belt was?
Why would you think the previous owner had the wrong pulley on there anyway?
Stupidity is expensive!!
Wed Jun 08, 2016 5:06 pm
:lol:
Wed Jun 08, 2016 5:08 pm
Haha. Well guess you live and learn.
No gauge I had over an inch flex in the belt. Consulted GT. And that was the consensus.
Well off I go into uncharted water....
Guess this is more of a point and laugh thing. Not so much a help ya out kinda thing.
Wed Jun 08, 2016 5:34 pm
Thats definately a good one!
Wed Jun 08, 2016 5:38 pm
Were you going to swap the crank or the whole powerhead?
-Custom pool noodle
-stage 4 water wings
Wed Jun 08, 2016 5:41 pm
Am I not looking at the ass-end of a broken crankshaft in that pic?
-Custom pool noodle
Wed Jun 08, 2016 5:49 pm
Yes, you are. Not sure if he knows that though.
Wed Jun 08, 2016 5:58 pm
Wed Jun 08, 2016 6:02 pm
Wed Jun 08, 2016 6:03 pm
No dude. Just no.
Wed Jun 08, 2016 6:06 pm
Wed Jun 08, 2016 6:07 pm
The part that's in the planetary is the crankshaft EXTENSION. What you see in that case cover is PART of the crankshaft, the missing part broke off and is what is sticking out of the extrnsion, and has a keyway. You broke the crankshaft.
Wed Jun 08, 2016 6:10 pm
You can get a whole new crank.
Depends on what you want to work on.
Wed Jun 08, 2016 6:12 pm
Wed Jun 08, 2016 6:15 pm
My apologies, I was briefly second guessing myself due to all the dumb being posted in this thread :lol:
OP, find yourself a service center or someone who has a clue to work on that thing FOR YOU. I.e. Put the pieces in a box, and take to someone else....
-Custom pool noodle
Wed Jun 08, 2016 6:27 pm
Where you located, firedawg? There are people here that will help if you ask for it.
Wed Jun 08, 2016 6:32 pm
Wed Jun 08, 2016 6:51 pm
Wed Jun 08, 2016 7:07 pm
yall didn't know? that's a motor from 1999, it's a reverse twist lock shaft. things are badass. it actually came with a 46.5 tooth gear! and a 3.5 blade, 19 pitch prop.
orrrrrrrr.......
AKA has built a new revolutionary slip shaft that shears the fuck off convincing the buyer to buy a different gear...........?
oooooorrrrrr......... this dude ate a bowl of fucking rocks and fucking swallowed!
Wed Jun 08, 2016 7:27 pm
You guys are so mean.
Wed Jun 08, 2016 7:29 pm
This is fuckin priceless!!!
Subscribed!
Sent from denda this
Wed Jun 08, 2016 7:30 pm
Bruh, I can't stop laughing at the comments on this post. That meme, the AKA comment, y'all fucking funny!!!!!!!!
40HP Gatortail
Wed Jun 08, 2016 7:32 pm
Where is fucking Delta Duck Master when you need him
40HP Gatortail
Wed Jun 08, 2016 7:34 pm
Why would we need captain fat fingers?
Wed Jun 08, 2016 7:41 pm
I'm still wondering wtf he is talking about! The crank is broke the fuck off!
Does he think that it's supposed to be like that?
If he can't look at it and tell there's a bigger problem than getting the shaft out of the planetary he needs to do like someone else said and take it to a shop.
But I'll indulge him
Use an impact to unscrew the bolt from the end of the crank near the brake rotor and pull that side of the planetary out.
Then slide the outer planetary case off of the shaft extension.
Re install the bolt that was holding the brake rotor and use a three jaw puller to remove your shaft extension from your BROKEN CRANKSHAFT end.
Then tap the clutch off of your BROKEN CRANKSHAFT end.
Hope this helps
Wed Jun 08, 2016 7:47 pm
Btw, the shaft EXTENSION slides pretty easily out of the planetary
To get the crankshaft out of the extension, you'll need to remove the bolt, and knock them apart.
Wed Jun 08, 2016 7:51 pm
That's blasphemy Russ. The crank and drive shaft just mate in the planetary.
Wed Jun 08, 2016 7:59 pm
That chit will buff out. Bring it to a welder and tell him to get something round and burn it in there hott!
Sent from my beeper
Lmfao. I reckon he could always just thread it and use a longer bolt.
Wed Jun 08, 2016 8:02 pm
Wed Jun 08, 2016 8:08 pm
I thought the crank came in from the front? nothing short of a 3lb sledge and some ****** effort..........3lb sledge and 1 swing from the front aND a new crank is in there like xnothing! know the old out the opposite way!
This is wayy better that bow rope storage!
Wed Jun 08, 2016 8:11 pm
this is one person I would honestly tel to go fuck my wife. lord knows it is gonna be a fucking show.
Wed Jun 08, 2016 8:12 pm
Wed Jun 08, 2016 8:14 pm
This worked best when mine broke off like that. Get the 5/8" size.
Wed Jun 08, 2016 8:19 pm
it's actually a 7/16 -20 thread pattern on the shaft extension bolt. and you can actually use a bolt that is 2 inches longer than what gator tail puts in there. I got longer ones as I have bent 2 pulling shit appart. buuuutttt.....
he may need a 20 inch longer one to go throught from the front side!
By the way my wife is down. as in she is asleep, and you will probably post a new thread for help on waking a female to fuck. but in all honesty, best practice is to stick and move, you know like a boxer, you are half way done before she wakes and she won't argue.........TRUST ME!
Wed Jun 08, 2016 8:28 pm
