It is currently Sun Apr 12, 2026 9:48 am
Reply to topic  [ 17 posts ]
 GTR Stage 1 speeds
Post GTR Stage 1 speeds
My gator tail is doing about 28-29 in deep water and 30-31 in shallow water. I've got heads, cam, and marshmallow with no baffles. It's a 17x54 gator tail boat, just wondering if that's normals speeds
Delta lvl 3 GTR with MAC
16x54 Gator hull
Mon Jul 11, 2016 9:10 am
Post Re: GTR Stage 1 speeds
Sound good to me :D
Mon Jul 11, 2016 9:13 am
what rpm?
Burlap Brothers
Mon Jul 11, 2016 9:32 am
3900-3950
16x54 Gator hull
Mon Jul 11, 2016 2:54 pm
Mon Jul 11, 2016 7:34 pm
Won't lie to you I just bought the boat like that and I have no clue but the air filter is stupid dirty, and I have some bushing out where the motor turns and it is very loose, like the motor bouncing in the water, you think any of this could have to do with ? Or maybe the carb needs to be adjusted ?
16x54 Gator hull
Mon Jul 11, 2016 8:01 pm
Motor is a 2010 and it hits about 4600 max rev out the water and 4100 trimmed up all the way in the water
16x54 Gator hull
Mon Jul 11, 2016 8:05 pm
pm sent.
But that thing should be around 4200 rpm's like I said.
Let me know if you want to mess with it.
Mon Jul 11, 2016 8:16 pm
Mon Jul 11, 2016 8:47 pm
I have a 2007 GTR on a 1746 with just a mikuni and a baffled marshmallow. I run 30-31 with one other person ( bounces too bad by myself) at about 4100-4200 so I would think you should faster and would turn a few more RPMs that's just my opinion.
Wed Jul 13, 2016 11:17 am
If it is a 2010 it probably has a 45 Tooth lower pulley. A "stage 1" with heads and cam.. will run about 4000 RPM.
That sounds about like Hoyt's old mod recipe of .020" decking and a 280 ish cam.
Wed Jul 13, 2016 12:11 pm
yea maxxis hoyt is the one who did the work to it, i found out my prop was a little worn out thats why was getting those speeds, doing a lot better now with new prop haha
16x54 Gator hull
Thu Jul 14, 2016 7:30 pm
16x54 Gator hull
Prop work
Fri Jul 15, 2016 7:00 pm
Just read where you did that. Makes a huge difference.
Just curious, what kind of speed and rpm did you get with your new prop?
Fri Jul 22, 2016 1:36 pm
I'm pretty sure he's around the 4050-4100 rpm range and he's around 30 deep 31-32 shallow.
Fri Jul 22, 2016 7:41 pm
