Re: Help with electrical question.
Did you know that when dc passes thru a wire that the electrons actually go from - to +, leaving a "hole" as they travel, we actually view the "hole" flow as + to - . I wanna know why the charging system didn't fry or is it still working? As far as the starter goes the magnets attached inside the housing never changed, so when voltage was applied to the stator(armature) creating the magnetic field, it still had the "potential" to travel in the correct direction. Had the magnets not been used but another set of field coils then yes the starter would have traveled backwards. This is the PFM of electronics! (Pure F--King Magic
) Hope that helps.
My most repair for computers when I worked as an Electronic tech/IT was a "PEBKAC". Problem Exist Between Keyboard and Chair.
