It is currently Thu Apr 09, 2026 10:33 am
Reply to topic  [ 8 posts ]
 MB 45 Mag strange clutch issue
Post MB 45 Mag strange clutch issue
I have a 2010 mud buddy 45 mag with about 180 hours. I was on the river yesterday and ran for about 30 minutes to the duck hole no problems. Finished hunting and start to head back to the ramp. About 5 minutes in to the ride the clutch disengages itself. This happened multiple times at WOT. I try putting along at 2,000 rpm and the clutch will stay engaged for anywhere from 5-10 minutes then will disengage. Try WOT a couple more times and clutch disengages after about 10 seconds. I limp back to the ramp at 2,000 rpm with the clutch disengaging intermittently. While on the water I opened up the football to check connection at the clutch switch and everything seemed fine. Could the switch be going bad or does this sound like a bad clutch? Any other suggestions? Thanks.
Mon Jan 30, 2017 10:36 am
Post Re: MB 45 Mag strange clutch issue
Sounds like wiring. Inspect wiring to clutch, might even pull clutch cover to inspect the wiring where it goes through the frame.
Mon Jan 30, 2017 10:49 am
Check switch, had 2 go bad on a GTR, if that switch ain't 30 amp rated, replace it with one that is. An electrical coil engages the clutch, a coil is nothing more than a piece of wire, in other words almost like a short. Yes it will heat up any bad or questionable connections.
Mon Jan 30, 2017 11:21 am
When I had this issue it was the switch going bad
1854 Prodigy DPE Level 3 HDR
Mon Jan 30, 2017 1:02 pm
Check the clutch mounting bolt.
_________________________________
Alumacraft 1546 AW/Mudbuddy 27 Mini
Mon Jan 30, 2017 3:54 pm
Mon Jan 30, 2017 8:35 pm
Sounds like a short in the wire harness some where. Since you checked the football area, pull cover and check inside the belt box and see if a wire hasn't been rubbed bare. Also check closer in the football. Those wires are stuffed in there pretty tight.
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Tue Jan 31, 2017 10:58 am
Talked to Boat Dr. and got a new switch and relay headed my way. I'll also pull the cover and check the wiring to the clutch. Hopefully one of these things fixes the issue. Thanks.
Fri Feb 03, 2017 2:16 pm
