It is currently Sat Mar 21, 2026 2:30 pm
Reply to topic  [ 6 posts ]
 23 stage 1
Post 23 stage 1
Thinking about bumping my stock mud buddy mini up to a stage 1. The kit from bps comes with carb, intake manifold, heads and exhaust. Am I going to need to replace the valves, pushrods and rollers as well? The motor has 75hrs on it and runs strong. I am going to have to replace the case gasket this off season because it’s starting to leak a bit. I figure when I replace the gasket I might as well do the cam as well. Any recomendations on cams?
Sat Jan 27, 2018 6:47 pm
Post Re: 23 stage 1
Not need to change rods and rockers. If you get a worked set of heads from bps, the stainless valves will be installed
HOTSAUCE170 wrote:
Sun Jan 28, 2018 3:31 pm
Post Re: 23 stage 1
Is it pointless to do the carb and exhaust without replacing or decking the heads?
Mon Jan 29, 2018 7:19 am
Post Re: 23 stage 1
You may see some gain but yes the heads are important.You can add some timing to "cheat" some cylinder pressure wich will get you by for a while,, the stock ports on a 23 are tiny and really wake up with ported heads
Mon Jan 29, 2018 8:46 am
Post Re: 23 stage 1
Got a good deal on a set of dual exhaust. Now looking for heads and a carb
Wed Jan 31, 2018 6:43 pm
Post Re: 23 stage 1
Sat Feb 03, 2018 1:22 pm
