It is currently Fri Mar 27, 2026 3:33 am
[ 6 posts ] |
GaSwampFox
 23 stage 1
Thinking about bumping my stock mud buddy mini up to a stage 1. The kit from bps comes with carb, intake manifold, heads and exhaust. Am I going to need to replace the valves, pushrods and rollers as well? The motor has 75hrs on it and runs strong. I am going to have to replace the case gasket this off season because it’s starting to leak a bit. I figure when I replace the gasket I might as well do the cam as well. Any recomendations on cams?
| Sat Jan 27, 2018 6:47 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 Re: 23 stage 1
Not need to change rods and rockers. If you get a worked set of heads from bps, the stainless valves will be installed
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
| Sun Jan 28, 2018 3:31 pm |
GaSwampFox
 Re: 23 stage 1
Is it pointless to do the carb and exhaust without replacing or decking the heads?
| Mon Jan 29, 2018 7:19 am |
Will C
 Re: 23 stage 1
You may see some gain but yes the heads are important.You can add some timing to "cheat" some cylinder pressure wich will get you by for a while,, the stock ports on a 23 are tiny and really wake up with ported heads
| Mon Jan 29, 2018 8:46 am |
GaSwampFox
 Re: 23 stage 1
Got a good deal on a set of dual exhaust. Now looking for heads and a carb
| Wed Jan 31, 2018 6:43 pm |
50fps
 Re: 23 stage 1
| Sat Feb 03, 2018 1:22 pm |
[ 6 posts ] |
