It is currently Fri Sep 19, 2025 10:50 am
Reply to topic  [ 21 posts ]
 37 EFI GTR
Post 37 EFI GTR
I ran into an issue yesterday. My 37 EFI GTR won't run any higher than 3100-3200 RPM without dying out. What I mean by dying out is, it seems like it is surguring. RPMs will drop all the way down like it dies and then kicks back up. But it is constant. You never are able to get it to run. Any suggestions? I am going to call Gator-Tail this morning but was looking for any input.
1860 SD w/35 HP Vanguard Surface Drive
Tue Mar 24, 2015 6:43 am
Post Re: 37 EFI GTR
that is a nice looking motor - great paint scheme
you checked all the "easy" stuff like fuel lines and tank vent?
air filter is clear?
Tue Mar 24, 2015 7:14 am
Post Re: 37 EFI GTR
thanks. i love the color scheme
yeah i checked all of that yesterday on the water. even removed the fitting and put the line straight in the tank.
Tue Mar 24, 2015 7:58 am
Post Re: 37 EFI GTR
Electronics???
Tue Mar 24, 2015 8:12 am
Post Re: 37 EFI GTR
Sounds like a fuel pump failure of some sort to me. Need around 40 psi.
Tue Mar 24, 2015 8:17 am
Post Re: 37 EFI GTR
Find the MAF and unplug it. See if that changes how it runs, if not you know you've got a metering problem.
Tue Mar 24, 2015 8:18 am
Post Re: 37 EFI GTR
So you think it should hold 40 psi wot?
I have no idea what the MAF looks like on a gator tail. You have any pics of one?
Tue Mar 24, 2015 8:35 am
Post Re: 37 EFI GTR
Did you talk to Gator tail yet ??
1754 With Level 3 GTR
Tue Mar 24, 2015 11:07 am
Post Re: 37 EFI GTR
I spoke with them this morning and he said he wasn't sure what was going on. Stated i needed to bring it in to the closest dealer. My issue is the closest is 1.5 hours from me and only open 8-5 m-f and 8-12 on saturdays. so i figured if it was just a simple fuel issue then i would go ahead and take care of it myself.
Tue Mar 24, 2015 12:05 pm
Post Re: 37 EFI GTR
I would leave it alone and take it in for warranty work
Tue Mar 24, 2015 3:49 pm
Post Re: 37 EFI GTR
Hardin County Tractor is now handling Gator Tail motors. Not sure if that is any closer to you. They are in Kountze.
http://www.southeasttexas.com/classifie ... distance=0
Wed Mar 25, 2015 3:27 pm
Post Re: 37 EFI GTR
Wed Mar 25, 2015 9:11 pm
Post Re: 37 EFI GTR
Alright here is the latest and greatest. Took it to a briggs dealer since it was a motor issue and they told me a wire was broken and briggs would not warranty it. Not sure what wire because the mechanic was not there. I am going back today or tomorrow to find out where and also going to find out why.
Tue Apr 07, 2015 10:02 am
Post Re: 37 EFI GTR
WTF - didn't they make any notes on the work order how hard would it have been to fix a broken wire once they found it?
Tue Apr 07, 2015 10:35 am
Post Re: 37 EFI GTR
Um I thought it had a map and not a maf
Tue Apr 07, 2015 8:21 pm
Post Re: 37 EFI GTR
I just ran in to the same problem today after only 6 hours on my brand new 37 efi!!! So frustrating. I pulled the battery out and realized the nut on the negative side had shaken loose and now there is no power from the motor. If you try to give it gas it increases for 1 second then completely looses all power or shuts off. What is the deal!!! ??? anyone else???
Thu Apr 30, 2015 11:45 pm
Post Re: 37 EFI GTR
Post Re: 37 EFI GTR
Fri May 01, 2015 4:57 am
Post Re: 37 EFI GTR
Fri May 01, 2015 6:00 am
Post Re: 37 EFI GTR
Did you ever get it figured out? I still have no power at all and noone seems to know what to tell me to try. Thanks
Sun May 03, 2015 4:16 pm
Post Re: 37 EFI GTR
Fri Aug 14, 2015 2:06 am
