jakecologne
Joined: Thu Jun 10, 2010 2:57 pm Posts: 933 Location: Des Allemands
 exhaust problem
I have an EVT exhaust. when running sounds like I have a leakin sound almost. all the gaskets are good. no cracks in exhaust. it doesn't have to true sound of the exhaust
_________________ 16x44 Hanko Skiff 35GTR
Mon Oct 01, 2012 7:46 pm |
jakecologne
 Re: exhaust problem
ttt
Tue Oct 02, 2012 5:25 am |
JLACOUR
Joined: Wed Jan 14, 2009 8:18 pm Posts: 4915 Location: Lake Jackson, TX
 Re: exhaust problem
_________________ 37 PD EFI FPR 18x48 Tiller SOLD -- 36 PD EFI FPR 18x48 Stick Steer SOLD -- 27 PD FPR 16x36 Skiff
Tue Oct 02, 2012 6:45 am |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
 Re: exhaust problem
Just cause a exhaust gasket looks good doesn't mean it's dealing double them up and see if that helps I have to do that with my MM cause the flanges are a lil warped
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
Tue Oct 02, 2012 8:22 am |
jakecologne
 Re: exhaust problem
it doesn't have baffles. it sounds like the noise is coming out one of the heads. I heard my evt and another evt without baffles side by side and can tell mine doesn't have the true sound
Tue Oct 02, 2012 9:09 am |
deltaduckmaster
 Re: exhaust problem
Maybe the weld to the flange is broke. The weld is on the inside.
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
Tue Oct 02, 2012 10:21 am |
jakecologne
 Re: exhaust problem
this is 2nd exhaust that did that for me so I'm starting to think its something with the engine rather than the exhaust
Tue Oct 02, 2012 10:32 am |
deltaduckmaster
 Re: exhaust problem
Light material with heat. Shut is gonna break
Tue Oct 02, 2012 10:40 am |
jakecologne
 Re: exhaust problem
got home an took at look at it the noise sounds like its comin from the engine itself not the exhaust
Tue Oct 02, 2012 4:48 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: exhaust problem
Pull the cover & check the rockers & push rods. Might just need set valve lash.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
Tue Oct 02, 2012 5:00 pm |
jakecologne
 Re: exhaust problem
that would make it sound different ?
Tue Oct 02, 2012 5:59 pm |
Team Camo
 Re: exhaust problem
Sorry, just reread, thought you said it was making knocking sound. Nevermind, probably a leaking slip flange.
Tue Oct 02, 2012 6:31 pm |
jakecologne
 Re: exhaust problem
my previous crossover exhaust that didn't have slip flanges made the same noise
Tue Oct 02, 2012 6:58 pm |
Beadlejuicejr
 Re: exhaust problem
Pull off your exhaust check the welds on the inside the flange of they are craked. Put it back on with double gaskets and see if it continues. Start checking stuff only way you gonna figure it out
Tue Oct 02, 2012 7:25 pm |
deadbird8
 Re: exhaust problem
Thu Oct 04, 2012 5:23 am |
jakecologne
 Re: exhaust problem
new gaskets, no cracks in flanges. still makin same noise
Thu Oct 04, 2012 5:31 pm |
Beadlejuicejr
 Re: exhaust problem
Have you checked your valves. Do you have any mods on your motor
Thu Oct 04, 2012 5:35 pm |
jakecologne
 Re: exhaust problem
carb an exhaust. do u think that my valves just need to reset ?
Thu Oct 04, 2012 5:43 pm |
Beadlejuicejr
 Re: exhaust problem
Check them for sure and see. I was thinking check your governor block make sure it's still in the right place and didn't move or anything
Thu Oct 04, 2012 6:01 pm |
jakecologne
 Re: exhaust problem
what could the gov block cause
Beadlejuicejr
 Re: exhaust problem
Your governor shaft could just be doing what it wants
Thu Oct 04, 2012 6:10 pm |
jakecologne
 Re: exhaust problem
causing the exhaust to sound different ?
Thu Oct 04, 2012 6:12 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 Re: exhaust problem
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Thu Oct 04, 2012 6:36 pm |
pokey79
Joined: Mon Nov 15, 2010 4:50 pm Posts: 2282 Location: Circumcised, Louisiana
 Re: exhaust problem
crank it up and use ur hand to see if u can feel air coming from somewhere
Thu Oct 04, 2012 6:43 pm |
jakecologne
 Re: exhaust problem
I'm gettin my valves an what not checked tomorrow
Thu Oct 04, 2012 7:04 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: exhaust problem
could have a small head gasket leak, is it coming from both sides or just one?
Thu Oct 04, 2012 8:12 pm |
jakecologne
 Re: exhaust problem
sounds like just one side. there is no oil any where that shows a leak. the valves haven't been checked in a couple hundred hours
Thu Oct 04, 2012 8:34 pm |
Woodiebuster
 Re: exhaust problem
Pour just a little Auto Tranny fluid down the carb, itll smoke like a Mofo and you will be able to see any leaks.
Thu Oct 04, 2012 8:40 pm |
take'emgator
 Re: exhaust problem
Pressure up the cylinder like you are doing a leak down test and see if you have any leaks around the head gaskets just to eliminate that, check valve springs to make sure your didn't break one, that would jack with a valve and make the motor sound weird and run different, make sure all your valve train is still infully intact.
Thu Oct 04, 2012 8:45 pm |
jakecologne
 Re: exhaust problem
the motor seems to be running fine but I will get all the valves an springs checked out tomorrow
Thu Oct 04, 2012 8:48 pm |
jakecologne
 Re: exhaust problem
if it wasn't for the shitty air sound coming out my exhaust it would be all good
Thu Oct 04, 2012 8:49 pm |
richard nagon
 Re: exhaust problem
well at two hundred hours i think u just found a starting point. valves should be cked at every 50 hrs. looks like takem has a new best friend soon to be customer. do a leak down.
_________________ JUST ANOTHER FARMER ON WELFARE
Thu Oct 04, 2012 8:50 pm |
take'emgator
 Re: exhaust problem
do you see any blackness arund the exhaust flanges like on the cylinder head, eliminate the exhaust gasket by changing them and putting 2 of them. Just some pointers, to help you along, casue trust me everyone on this page is gonna wanna know what it is lol
Right on Naggon, always chack valves from time to time, you can ruin a cam quick if one of them is out of wack and it don't take much
Thu Oct 04, 2012 8:51 pm |
jakecologne
 Re: exhaust problem
yea ill get all that checked tomorrow an get back to y'all. thanks for the help so far fellas
Thu Oct 04, 2012 8:52 pm |
jakecologne
 Re: exhaust problem
there is black on the heads where u can tell it was leaking. I changed gaskets today to eliminate that
Thu Oct 04, 2012 8:54 pm |
jakecologne
 Re: exhaust problem
valves reset an it sounds perfect
Fri Oct 05, 2012 5:46 pm |
Team Camo
 Re: exhaust problem
Amazing what a lil maintenance will do, huh?  Glad you finally got it lined out.
Fri Oct 05, 2012 5:57 pm |
jakecologne
 Re: exhaust problem
haha yea
Fri Oct 05, 2012 6:09 pm |
