It is currently Fri Jul 18, 2025 6:11 am
Reply to topic  [ 38 posts ]
 exhaust problem
Post exhaust problem
I have an EVT exhaust. when running sounds like I have a leakin sound almost. all the gaskets are good. no cracks in exhaust. it doesn't have to true sound of the exhaust
16x44 Hanko Skiff
35GTR
Mon Oct 01, 2012 7:46 pm
Post Re: exhaust problem
ttt
16x44 Hanko Skiff
35GTR
Tue Oct 02, 2012 5:25 am
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Tue Oct 02, 2012 6:45 am
Just cause a exhaust gasket looks good doesn't mean it's dealing double them up and see if that helps I have to do that with my MM cause the flanges are a lil warped
Tue Oct 02, 2012 8:22 am
it doesn't have baffles. it sounds like the noise is coming out one of the heads. I heard my evt and another evt without baffles side by side and can tell mine doesn't have the true sound
16x44 Hanko Skiff
35GTR
Tue Oct 02, 2012 9:09 am
Maybe the weld to the flange is broke. The weld is on the inside.
17x48 extreme stage 2 GTR
Tue Oct 02, 2012 10:21 am
this is 2nd exhaust that did that for me so I'm starting to think its something with the engine rather than the exhaust
16x44 Hanko Skiff
35GTR
Tue Oct 02, 2012 10:32 am
Light material with heat. Shut is gonna break
Tue Oct 02, 2012 10:40 am
got home an took at look at it the noise sounds like its comin from the engine itself not the exhaust
16x44 Hanko Skiff
35GTR
Tue Oct 02, 2012 4:48 pm
Pull the cover & check the rockers & push rods. Might just need set valve lash.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Oct 02, 2012 5:00 pm
that would make it sound different ?
16x44 Hanko Skiff
35GTR
Tue Oct 02, 2012 5:59 pm
Sorry, just reread, thought you said it was making knocking sound. Nevermind, probably a leaking slip flange.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Oct 02, 2012 6:31 pm
my previous crossover exhaust that didn't have slip flanges made the same noise
16x44 Hanko Skiff
35GTR
Tue Oct 02, 2012 6:58 pm
Pull off your exhaust check the welds on the inside the flange of they are craked. Put it back on with double gaskets and see if it continues. Start checking stuff only way you gonna figure it out
Tue Oct 02, 2012 7:25 pm
Thu Oct 04, 2012 5:23 am
new gaskets, no cracks in flanges. still makin same noise
16x44 Hanko Skiff
35GTR
Thu Oct 04, 2012 5:31 pm
Have you checked your valves. Do you have any mods on your motor
Thu Oct 04, 2012 5:35 pm
carb an exhaust. do u think that my valves just need to reset ?
16x44 Hanko Skiff
35GTR
Thu Oct 04, 2012 5:43 pm
Check them for sure and see. I was thinking check your governor block make sure it's still in the right place and didn't move or anything
Thu Oct 04, 2012 6:01 pm
what could the gov block cause
16x44 Hanko Skiff
35GTR
Your governor shaft could just be doing what it wants
Thu Oct 04, 2012 6:10 pm
causing the exhaust to sound different ?
16x44 Hanko Skiff
35GTR
Thu Oct 04, 2012 6:12 pm
HOTSAUCE170 wrote:
Thu Oct 04, 2012 6:36 pm
crank it up and use ur hand to see if u can feel air coming from somewhere
Thu Oct 04, 2012 6:43 pm
I'm gettin my valves an what not checked tomorrow
16x44 Hanko Skiff
35GTR
Thu Oct 04, 2012 7:04 pm
could have a small head gasket leak, is it coming from both sides or just one?
Thu Oct 04, 2012 8:12 pm
sounds like just one side. there is no oil any where that shows a leak. the valves haven't been checked in a couple hundred hours
16x44 Hanko Skiff
35GTR
Thu Oct 04, 2012 8:34 pm
Pour just a little Auto Tranny fluid down the carb, itll smoke like a Mofo and you will be able to see any leaks.
Thu Oct 04, 2012 8:40 pm
Pressure up the cylinder like you are doing a leak down test and see if you have any leaks around the head gaskets just to eliminate that, check valve springs to make sure your didn't break one, that would jack with a valve and make the motor sound weird and run different, make sure all your valve train is still infully intact.
Thu Oct 04, 2012 8:45 pm
the motor seems to be running fine but I will get all the valves an springs checked out tomorrow
16x44 Hanko Skiff
35GTR
Thu Oct 04, 2012 8:48 pm
if it wasn't for the shitty air sound coming out my exhaust it would be all good
16x44 Hanko Skiff
35GTR
Thu Oct 04, 2012 8:49 pm
well at two hundred hours i think u just found a starting point. valves should be cked at every 50 hrs. looks like takem has a new best friend soon to be customer. do a leak down.
Thu Oct 04, 2012 8:50 pm
do you see any blackness arund the exhaust flanges like on the cylinder head, eliminate the exhaust gasket by changing them and putting 2 of them. Just some pointers, to help you along, casue trust me everyone on this page is gonna wanna know what it is lol
Right on Naggon, always chack valves from time to time, you can ruin a cam quick if one of them is out of wack and it don't take much
Thu Oct 04, 2012 8:51 pm
yea ill get all that checked tomorrow an get back to y'all. thanks for the help so far fellas
16x44 Hanko Skiff
35GTR
Thu Oct 04, 2012 8:52 pm
there is black on the heads where u can tell it was leaking. I changed gaskets today to eliminate that
16x44 Hanko Skiff
35GTR
Thu Oct 04, 2012 8:54 pm
valves reset an it sounds perfect
16x44 Hanko Skiff
35GTR
Fri Oct 05, 2012 5:46 pm
Amazing what a lil maintenance will do, huh? :lol:
Glad you finally got it lined out.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Oct 05, 2012 5:57 pm
haha yea
16x44 Hanko Skiff
35GTR
Fri Oct 05, 2012 6:09 pm
Users browsing this forum: No registered users and 108 guests
