baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
 Re: New 65hp stock power head for mm's
get some pics/videos up - this is getting good
_________________ that's going itch when it dries
Mon Apr 28, 2014 1:09 pm |
brickgw
I can see it now....
Mon Apr 28, 2014 1:25 pm |
MarshJB
SwampShark: http://youtu.be/hIIvx09LznASent from my XT1080 using Tapatalk
_________________ 17x54 Extreme W/ GTR-35L Stage 1
Mon Apr 28, 2014 1:33 pm |
pintail_89
^^^|PAHAHAHAHA EXACTLY
Sent from my SAMSUNG-SM-N900A using Tapatalk
_________________ 19x48 MAD MAN CUSTOMS 36PD (stock for now)
barnes_53
Here y'all go. An image to make it interesting.
Engine Type: 2 cycle, two cylinder Bore: 76mm Stroke: 69mm Displacement: 625cc Compression: 9.5:1 HP Output: 65hp @ 6300rpm Torque: 55ftlbs @ 6000rpm Ignition: Dual CDI (Capacitive digital Ign.) Carburation: Dual 34mm slide or optional electronic fuel injection Fuel Pump: Auxiliary external pneumatic / electric pump with fuel injection Lubrication: Fuel mixed with oil @ 50:1 or optional oil injection Rotation: Counter clockwise, viewed from output end Starter: 12 volt electric, recoil, or both Alternator: 250 watt/20 amp alternator standard Cooling: Optional fan or free air cooled Weight: 73 lbs-free air, 79 lbs-fan cooled including electric start and exhaust. Optional gearbox adds 19 lbs. Reduction Units:G-50 gearbox available in 2.16:l, 2.29:l, 2.59:l, 3.16:l and 3.65:l ratios Cog belt belt drive also available. Drive Coupling: Elastomeric dampener or optional centrifugal clutch.
Dual Carb Recoil Start $5143.00 Dual Carb Electric Start $5763.00 Dual Carb Recoil Start Gear Box $6407.00 Dual Carb Electric Start Gearbox $6960.00 Fuel Injection Option $1591.00
More horsepower and torque per pound than any other engine in its class Recommended TBO is rated at 1000 Hrs @ 75% power Al-Nikasil coated cylinders
Mon Apr 28, 2014 1:36 pm |
pintail_89
BAAAADDDD!!!!
Mon Apr 28, 2014 1:38 pm |
Will
Like I said, PLENTY of options for the Horizontals, stumbled on many looking for Verticals.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
Mon Apr 28, 2014 1:44 pm |
MALLARDSX2
Joined: Wed Jan 28, 2009 6:34 pm Posts: 978 Location: GA
The real question is what is its torque at 1500RPM's??? I don't see that gear reduction case lasting 5 minutes...
Mon Apr 28, 2014 2:07 pm |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
Why stop at the 65hp model? I say man up and put the 110hp on it!
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
Mon Apr 28, 2014 3:29 pm |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
Lot of horses from a small engine. Will it hold up to the torture of digging your way out of almost dry mud holes every weekend?
_________________ 18'x54"CC Hanko/ 36PD
Mon Apr 28, 2014 4:22 pm |
Gameover
Joined: Tue Jan 03, 2012 9:06 am Posts: 3673 Location: Prarieville,LA
Also if u can't get gtr to commit and they don't sale just frames it will limit ur market to guys that have blown motor or u are now talking $7k for gtr and $6k for a motor
_________________ 1754 GTR Xtreme CC w/ Purple Kool-aid Additives
Mon Apr 28, 2014 4:24 pm |
Barroll
Joined: Fri Jan 15, 2010 10:19 am Posts: 932 Location: Georgia
I do not foresee a profitable business if your margin on this will be ~8% BEFORE overhead.....if this is truly "revolutionary" and you had it patented, you could have the higher hp mud motor market cornered....=make more money....sounds like alot of trouble to not make you max potential.
_________________ 1848 Prodigy 35 GTR
Mon Apr 28, 2014 8:06 pm |
cb5331
What kind of oil would we need to use in this new motor?
Mon Apr 28, 2014 8:08 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
Mon Apr 28, 2014 8:28 pm |
pintail_89
[attachment=-1]uploadfromtaptalk1398740015047.jpg[/attachment] don't understand the obsession in what yall are talkin about when these already exist? Someone explain
Mon Apr 28, 2014 8:54 pm |
banded-mallard
Tue Apr 29, 2014 5:02 am |
nasty
Seems like a more logical use of money rather than spending 6k of a lawnmower engine to get 15 more hp and dealing with cracked crank cases blocks ect ect. And pintail its bc its small enough to mount on a frame rather than have the back half of your boat taken up by an engine. It hangs off the back as they do now.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Tue Apr 29, 2014 7:07 am |
cupped up
Joined: Tue Jun 05, 2012 7:25 pm Posts: 4205 Location: St. Amant, LA
Tue Apr 29, 2014 8:09 am |
lunacris
Joined: Thu Mar 29, 2012 8:31 pm Posts: 3251 Location: Da Parish
_________________ GatorHide - MB
Tue Apr 29, 2014 8:36 am |
pintail_89
I don't think I would want that much power in a tiller handle. Yall is just crazy
Tue Apr 29, 2014 9:09 am |
cupped up
Tue Apr 29, 2014 9:32 am |
msm8281
There's lots of 60 horsepower outboard with tillers even some 90's
Tue Apr 29, 2014 9:47 am |
pintail_89
My buddy is gettin a 22x60 built right now and is puttin a merc 115 tiller on it
Tue Apr 29, 2014 10:06 am |
MarshJB
Tue Apr 29, 2014 10:07 am |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
If that is a 2 stroke motor there's no reason why it shouldn't rev to 5-6k rpm easily. Why they only turning 3k?
Sent from my beeper
Tue Apr 29, 2014 10:23 am |
nasty
Tue Apr 29, 2014 10:47 am |
dguidry
Joined: Tue Jun 29, 2010 1:20 pm Posts: 11166 Location: Cecilia, LA
_________________ Formerly:1648 Homemade Cypress Crawfish Skiff GTR23 Performance Cam and Heads; 17x46 Gator Tail with 35GTR and Hoyt's cam;s Currently: 17x48 Gator Tail with XD40 EFI. “Wisdom is not just expertise. It is knowing how much of various areas of expertise you need to know in order to make the decisions that the world needs and that you want to do,” Columbia University President Lee Bollinger.
Tue Apr 29, 2014 11:51 am |
pintail_89
Wont let me open it
Tue Apr 29, 2014 11:59 am |
nasty
Ditto
Tue Apr 29, 2014 12:37 pm |
dguidry
Tue Apr 29, 2014 12:38 pm |
dguidry
Tue Apr 29, 2014 12:39 pm |
banded-mallard
Good fucking god  . Open Deans link. At 65 hp 6500 rpm, the engine consumes 6.8 gal/hr. You better have a big fuckin gas tank.
Tue Apr 29, 2014 12:42 pm |
OwenDickeson
Mount that 78lb 50hp motor on a copperhead, and roll out.
Tue Apr 29, 2014 12:49 pm |
nasty
Does that mean 14x12 props?
Tue Apr 29, 2014 1:53 pm |
FRANKtheTAU
Joined: Thu Dec 29, 2011 10:30 pm Posts: 1386 Location: West TN
_________________ 40 Backwater SWOMP Lite / 1752 Alweld Mud
Tue Apr 29, 2014 1:54 pm |
baron von
Tue Apr 29, 2014 1:59 pm |
barnes_53
Tue Apr 29, 2014 2:27 pm |
pintail_89
Wed Apr 30, 2014 11:55 am |
pintail_89
Now this is a long tail but no one specified to just surface drives
quackconsumer
Well, the meeting with the lawyer was heart breaking to say the least. It seems as if there is a midget in Utah who is already trying to steal my design. We have both sent off for patents. It is out of my hands now, just have to wait and see which one of us will get awarded the rights to the design. My lawyer also advised me not to release any more info about the design as to not further complicate matters.
Sat May 03, 2014 8:34 pm |
